Message 1 of 5
Contract ending January 2022
Hi,
My broadband contract is due to expire at the end of this month. I phoned up to cancel, as I’m planning to move to another provider; and have been told I need to give 30 day’s notice. Is this correct if the contract is ending?
4 REPLIES 4
Message 2 of 5
Re: Contract ending January 2022
Yes, it's in the t&c's there's 30 days notice to cancel anytime. If you're moving to another openreach provider though just ask them to do a working line takeover & there's no need to cancel with BT
Message 3 of 5
Do not contact BT,  that is the incorrect procedure if moving suppliers. Just contact your new provider and they will do the rest.
Message 4 of 5
Thank you, I didn’t realise not to contact them 😔
Message 5 of 5
Thank you
