Buck1
Message 1 of 5
Contract ending
With my contract ending soon,it includes a mobile sim,am I able to cancel broadband and just keep the sim ?
4 REPLIES 4
mrnkar
Message 2 of 5
Re: Contract ending
Usually  broadband and mobile contracts are separate so you should be able to. If you go into your BT account you can check the dates. Also BT usually send emails when contracts are due to end with new deals etc.
-Richie-
Guru
Message 3 of 5
Re: Contract ending
You can but any broadband benefits will stop, so that means the mobile will increase by £5 per month, any Halo benefits like double data, fastest 4G speeds and other perks would also be removed.
Buck1
Message 4 of 5
Re: Contract ending
Thanks very much,it was what I expected but had to make sure
Buck1
Message 5 of 5
Re: Contract ending
Thank for the reply
