grannyand
Message 1 of 3
Cost of sending text on landline?
I have a text-enabled handset and base unit for my landline number.
What does it cost to send a text on the landline?  Is it charged the same as a phonecall?
Is it included in my 700 inclusive minutes, or excluded from that?
2 REPLIES 2
pottyperson
Distinguished Guru
Distinguished Guru
Message 2 of 3
Re: Cost of sending text on landline?
You need to subscribe to Caller Display and it's 10.5p per message sent. Details here.
grannyand
Message 3 of 3
I  had sent a couple of texts before wondering what it cost, so that's very helpful.   Thanks!
