Del37
Newbie
Message 1 of 4
Credit file
Can anyone tell me how to get bt to update my credit file to say my account is satisfied any help would be great
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: Credit file
@Del37  Thanks for posting. You will need to log a dispute by contacting Equifax on 0800 014 2955. Calls are free from a BT landline, charges from other networks and mobiles may vary.
Or, you can visit www.equifax.co.uk/ask for help.
You can also write to them at:
Equifax Ltd
Customer Service Centre
PO Box 10036
Leicester
LE3 4FS
If there's an error Equifax will contact our acquisitions team and have the default investigated. Usually it takes up to 21 days to review each case and the account will show as in query on the Equifax credit report until the issue is resolved.
Neil
Community ModeratorNeilO
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Del37
Newbie
Message 3 of 4
Re: Credit file
I tried that but they said i didnt have an equifax account so couldnt help
alfonzo
Message 4 of 4
Re: Credit file
