zarbe
Message 1 of 4
DELETE unwanted BT ID
Hi all i would like to delete a unwanted BT ID that was crreated for another person in my family which i no longer require and i want to be deleted. I know this can be done and it can only be done by the MODS please see this thread:
https://community.bt.com/t5/Bills-Packages/Remove-BT-ID/td-p/1788577
PLease can a MOD kindly allow me to contact them for this to be done thanks again.
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: DELETE unwanted BT ID
Hi @zarbe,
I'll be able to delete that unwanted BT ID. Please can you send me in your details using the "Contact The Mods" link found in my profile?
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
zarbe
Message 3 of 4
Hi Paddy i have already sent my details yesterday but did not get ny contact please can any Mods  advise when i will be contacted thanks all.
Moderator
Moderator
Message 4 of 4
Hi @zarbe we do have your details and you are near the top of the queue. One of the team will be in touch soon.
Cheers
John
Community ModeratorJohnC
Kudos”
