jl2271
Message 1 of 4
Default On Credit File
Hi,
Can someone please help? I have a default noted on my credit file which I have disputed with Equifax and have now been told I must contact you to have it removed.  I've tried calling but not getting anywhere.  I really need this removed as it is affecting my credit.
Thanks.
3 REPLIES 3
NeilO
Moderator
Moderator
Message 2 of 4
Re: Default On Credit File
Hi, @jl2271 welcome to the community and thanks for posting. That's not the correct process, if the default has been applied in error Equifax need to liaise with a specialist team in BT directly to get it removed.
I'll send you a private message to get in touch with the moderation team and we'll be happy to see if there is anything we can do to help.
Neil
RobbieMac
Moderator
Moderator
Message 3 of 4
Hi @jl2271
Thanks for taking the time to send us over your details.
I tried calling you back this morning.  I'm sorry that the default was added to your credit file.  I sent you a private message this morning to let you know I got that all sorted out for you.
All the best,
Robbie
RobbieMac
Moderator
Moderator
Message 4 of 4
Moved:
