Message 1 of 4
Do I have BT Sport or not?
I don't even know if I have BT Sport or not. This appears on mybill:
BT Sport Pack  £0.00
This is the cost of your BT Sport on APP ONLY at £0.00 a month, charged in
advance from 11 Feb 2019 to 10 May 2019
I don't have BT Sport on my Sky system and I cannot log in to the BT TV app.
Man Sad
3 REPLIES 3
Message 2 of 4
Re: Do I have BT Sport or not?
BT Sport Pack  £0.00
Man Sad
Hi @RobNBeeTee. You should note the BT Sport App is not the same as the BT TV App.
Message 3 of 4
Yes you have BT Sports, app only so no Sky TV, supported on ios and Android devices.
Did you get it free because you're a BT Mobile customer with 6GB data or more ?
Message 4 of 4
Forehead slap!  Smiley Embarassed
Thank you. I was using the wrong app. I do have BT Sport on the correct app.
