Message 1 of 4
Do need/get new router?
Hi guys just order full Fibre 900 and was wondering if I  get a new router with this package I currently have a smart hub 2.  I want to be able to use my ps5 at full speed, I've just learnt there's WiFi ax that goes at 1200meg  if this case I can avoid wiring the ps5 as that means running very long ethernet cable
3 REPLIES 3
Message 2 of 4
Re: Do need/get new router?
You should be able to go to hub manager and then you can turn on FTTP which converts 1 of the Ethernet LAN ports to a WAN port to connect to the openreach ONT
Message 3 of 4
The smart hub2 is the latest hub that BT have.
No idea why you think you need that sort of speed to play online.
Message 4 of 4
To download not to play online games
