BoutTime
Message 1 of 5
Downgrading from Infinity 2 to Infinity 1 at end of current contract - Do I have to re-contract?
Hi,
As per the title, my Infinity 2 contract has come to an end and I'm getting 49 meg download speeds.
I figure I may as well save some money and downgrade to Infinity 1 and get the same download speeds and slightly slower upload speeds. Are BT going to insist I sign up for another 12-18 months?
Many thanks in advance.
4 REPLIES 4
Message 2 of 5
Re: Downgrading from Infinity 2 to Infinity 1 at end of current contract - Do I have to re-contract?
BoutTime
Message 3 of 5
That's annoying......but thanks anyway.
BoutTime
Message 4 of 5
Just a quick update in case anyone was thinking of doing the same. I've just downgraded from Infinity 2 to Infinity 1. No re-contract was required. The guy explained that only upgrades require a fresh contract term.
I also removed BT TV so I'm free to add it back on at any time (and get another YouView+ Box Smiley Wink).
Message 5 of 5
If I were you I would phone up and double check that you are not in a contract. It would be very unusual for BT to allow an out of contract/minimum term customer to change of package, up or down, without putting you on a new contract.
