sethompson84
Message 1 of 10
End of tether
I have now contacted BT multiple times about the fact that my new landline is still not working. The broadband is also not working properly
They keep telling me they will send an engineer when I call. I have now waited 3 different days, no engineer but when I go online it says engineer has visited!
my landline and broadband STILL not working!
9 REPLIES 9
CJT80
Recognised Expert
Message 2 of 10
Re: End of tether
@sethompson84
This is a customer to customer support forum.
Do you know if a engineer/fault has been raised?
You can check this in your account online.
Kind Regards
CJT80
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
sethompson84
Message 3 of 10
Re: End of tether
Hello
yes I’m aware of that, this was a last resort really.
An engineer has been arranged several times, meant to visit today and againdidn’t appear, I went on to the online tracking and it says engineer has visited and problem fixed, but it’s not. No engineer visited.
I work for NHS and do telephone clinics which I’m meant to do from home 2x per week, but without a landline and functioning broadband I can’t do this.
Can anyone advise who I need to speak to other than the call centre as this cycle will continue!
Keith_Beddoe
Message 4 of 10
Re: End of tether
What broadband package did you order, as it may be worth doing a few checks, as its normally self install, without any visits, unless the installation fails?
What date were you told that the service was now active?
sethompson84
Message 5 of 10
Re: End of tether
hello
thank you for your reply
service was active mid November, not worked. We have done all the self install and checks etc, several times before contacting BT and every time we have called BT the guys have checked again and there is a fault.
we think it’s maybe to do with the new socket, hence the need for engineer
Keith_Beddoe
Message 6 of 10
Re: End of tether
@sethompson84
What does your master phone socket look like?
sethompson84
Message 7 of 10
Re: End of tether
Hi
looks like number 2 called ‘master socket 5 c’
s
Keith_Beddoe
Message 8 of 10
Re: End of tether
@sethompson84 wrote:
Hi
s
Have you removed the front section, and plugged a phone into the test socket behind, to see if you get dial tone on your phone?
This picture shows the correct way to test, using the test socket.
nte 5c testing from test socket.jpgNTE 5C Test socket check
Pedigree500
Message 9 of 10
Re: End of tether
If your employer is requiring you to work from home and you can't get a working landline then you need to get your employer to provide you with a mobile phone and a 4G router.
StuartH
Moderator
Moderator
Message 10 of 10
Re: End of tether
Hi sethompson84
Had you any luck when trying in the test socket?
I've sent you a private message asking for some further details to see if we can help resolve this for you.
Stuart
