mrtim
Message 1 of 3
Error code con-0067 with topcashback
Hey guys
So I have been trying to sign up to BT infinity 1. Everyone I try I get the same error at the checkout.
I have talked to the options team and they say there is an issue with my address and I can sign up over the phone. If I do this I miss out on the £92 cash back offer from topcashback.
Please can you advise?
Tags (2)
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: Error code con-0067 with topcashback
Hi @mrtim,
If you place the order offline you will miss out on the TCB referral. Has the team told you why it can't be placed online? Is it an address issue? Did you speak with an Easy Assist team before?
DanielS
Community ModeratorDannyS
Show your appreciation!
Kudos”Kudos”
mrtim
Message 3 of 3
Yes they said they had multiple addresses. I asked them to sort it but the woman didn't think she could.
