Message 1 of 7
Fibre broadband deals
Hi
I got a letter from Bt with fibre broadband deals.
I thought i will swap to Bt because my contract will end soon, but can´t order a Fibre broadband.bt3.jpgbt2.jpg
I typed in my postcode and landline number and got fibre broadband offer, but if i continue in my order I got the message that the package is not available and i have to choose other package, what I am not interested.
Thanks for help
Tom
6 REPLIES 6
Message 2 of 7
Re: Fibre broadband deals
Welcome to this user forum.
Who are you moving from?
Its possible that the fibre cabinet is full?
Message 3 of 7
Hi, thanks for quick reply, my current provider is talktalk.
And I have no idea about the cabinet, maybe.
Message 4 of 7
enter your address and post results  delete address  https://www.btwholesale.com/includes/adsl/main.html
Message 5 of 7
Message 6 of 7
As you can see there is a waiting list on your cabinet. If you give up current connection then you will lose your fibre connection and join the waiting list. Connection does not transfer with you
Message 7 of 7
Yes, anyway thanks you for explanation and your time.
