bork1138
Message 1 of 4
Fibre deal gone from order options, only offered 5mb/s
Hey!
We're set to move houses in the next month or so, and currently trying to figure out options for internet. Did the postcode checker last week and offered Fibre 80mb/s to the property. However today is now only offering 5mb/s-10mb/s and that fibre isn't available.
When I check the DSL checker says fibre is on a waiting list? I work in media so having a copper connection will basically make my life hell and damage my job opportunities. Is there anything that can be done or a way of knowing when I'll be able to order fibre?
Thank you!
3 REPLIES 3
imjolly
Message 2 of 4
Re: Fibre deal gone from order options, only offered 5mb/s
if you have used the dslchecker and currently showing a waiting list for your cabinet then there is nothing you can do but keep checking and as soon as you see available then place an order
bork1138
Message 3 of 4
Thank you, is there any way of being notified? And what would cause an availability of service? I can try check as much as possible but ideally must be a way of registering?
imjolly
Message 4 of 4
although it says waiting list there is no actual list and only way is for you to manually check to see if available
