MartinMcD
Message 1 of 23
Fibre is coming. I live rurally and do not presently have a landline?
My question is - do I need to get one in order to obtain Fibre when it comes?
I called and spoke to 3 people at BT but nobody could tell me the answer.
House was built 5 years ago in rural area. No landline was ever installed. Some neighbouring properties have landlines.
Do I need to get one or will I be able to obtain Fibre without one when the time comes in a few months?
22 REPLIES 22
Keith_Beddoe
Message 2 of 23
Re: Fibre is coming. I live rurally and do not presently have a landline?
@MartinMcD
You would need to follow the process for ordering a new phone line first. Once that has been provided, then the Openreach database will be updated and you will be able to see what broadband options are available to you.
Place an order for a line only using this link - https://www.bt.com/landline/deals
If the address doesn't appear properly when you enter the postcode, there is a section underneath where you can manually enter the address.  This will raise the order with the address showing as bronze and it will prompt Openreach to carry out a survey to confirm the routing.   Once the routing is updated the order will then progress as normal.  You can then add broadband once you have the line up and running.
licquorice
Message 3 of 23
Are you sure about that @Keith_Beddoe , it seems pointless ordering a copper line that will not be used now that we have SOGEA. Surely it must be possible to order FTTP directly without first having to provide an unused copper pair.
Copper routing is surely meaningless in the context of FTTP.
@MartinMcD  Give the FTTP team a call for advice 0800 587 4787
Keith_Beddoe
Message 4 of 23
@licquorice
I was suggesting that process to enable a routing to be built, either copper or fibre. If only a fibre route is available, the that would be determined by Openreach once an order is placed.
Nothing will happen at all until there is an order in the system.
licquorice
Message 5 of 23
Agreed, but surely that order doesn't have to be for copper.
gg30340
Message 6 of 23
According to this link, there is no copper cable and as such it obviously does not require you to order a copper land line first.
Full Fibre | FTTP Broadband | Fibre to the Premises | BT
garybs29
Recognised Expert
Message 7 of 23
If it's full fibre there shouldn't be any issues given they've recently started offering broadband without the facility to make calls anyway
licquorice
Message 8 of 23
SOGEA
MartinMcD
Message 9 of 23
Thanks very much, I will try that number.
I guess I just don't understand how the fibre gets from the cabinet 250m away to my house. There are underground phone lines to some close neighbouring properties so does the fibre cable go as far as that and then have to dig up my front garden?
I don't mind, just keen to understand really.
licquorice
Message 10 of 23
FTTP (full fibre to the house) doesn't come from the cabinet, it comes from a head end exchange. The will be a 'spine' fibre that will feed a number of distribution points which will either be in an underground chamber or on a pole depending on the way properties are currently served.
So either you will have an underground duct provided from the distribution point to your house or an overhead fibre from a pole.
