Message 1 of 2
Finding out information
Can I alter my bt package to wifi only with no other extras like homephone,television packages etc,and anybody know how much it costs just for the wifi? Does anybody know how long you are tied into a wifi only package?  Is it 12 or 18 months you are tied into wifi only package?  Can I alter my package over the phone?  Thanks for your help.
1 REPLY 1
Message 2 of 2
Re: Finding out information
It’s not WiFi it’s broadband, WiFi is how you connect can connect some devices like iPads  , iPhones  etc to your router ( your broadband router ).
Yes you can have broadband without phone or TV , the price for broadband only is obtained simply by removing the cost of the services you want removed from the bill , as you don’t say what you currently pay it impossible to say what you would ‘save’ but you can easily find out , just look at your bill , and remove the cost  of what you pay for your phone service and tv service…in my case , I have telephony that costs £3 a month , I’d obviously save £3 a month if I removed it .
You need to take into account if you are inside any minimum terms   ( in contract ) getting rid of some services while inside the minimum term attracts early termination charges , and if you get a discount for having a bundle of services, that discount may disappear if you don’t keep the bundle of services.
Most BT contract are 24months , 12 month ones are available but cost more per month .
Yes you can alter your package over the phone with the caveats about minimum terms and potential discounts
