Gurnek
Message 1 of 4
Fitbit delivery
How long does it take for the Fitbit to be delivered if I order on a Friday?
3 REPLIES 3
PaddyB
Moderator
Moderator
Message 2 of 4
Re: Fitbit delivery
Hi @Gurnek,
If you've order the FitBit it should arrive in around 5 working days. You should have received an order confirmation with a tracking reference as well.
PaddyB
Gurnek
Message 3 of 4
Re: Fitbit delivery
Hi, thanks for the reply, when I track it, it just comes up as processing
NeilO
Moderator
Moderator
Message 4 of 4
Re: Fitbit delivery
@Gurnek that's normal, it will track once it's been dispatched from the warehouse.
