Solved! Go to Solution.
Hi @Gurnek,
If you've order the FitBit it should arrive in around 5 working days. You should have received an order confirmation with a tracking reference as well.
PaddyB
@Gurnek that's normal, it will track once it's been dispatched from the warehouse.
