lorri-gem
Message 1 of 11
Free Fit Bit offer - No voucher emailed
Anyone ordered the BT package to take advantage of the offer of a free Fitbit - I was told a voucher would be sent by email 14 days after installation.  this has now passed and I have received no voucher.  Concerned because you only have 28 day to claim or lose it.   Cannot contact BT - On-line chat does not work  although it says quickest way to make contact.  If you are or have experienced this problem can you please let me know. Thanks Lorri
10 REPLIES 10
RobbieMac
Moderator
Moderator
Message 2 of 11
Re: Free Fit Bit offer - No voucher emailed
Hi @lorri-gem,
Welcome to the Community and thanks for your post!
Sorry that you haven't received the code to claim for your Fitbit gift.  What date did your services go live?
Cheers,
Robbie
lorri-gem
Message 3 of 11
Hi
14th November box received - set up and started on 17th November 2018.
thanks
RobbieMac
Moderator
Moderator
Message 4 of 11
Hi @lorri-gem,
Thanks for getting back to me to confirm that.
The process is that the code is emailed to you after the 14 days following activation.  I appreciate we're past that now.  Have you checked all the folders in your mailbox?  If you have and you still can't find the code you can send us over your details and we'll check this out.
Click on my username here >> RobbieMac << and you'll see our contact link underneath my profile picture.
Cheers,
Robbie
lorri-gem
Message 5 of 11
Hi
I have done as you ask, but I am not sure if the URL is correct, as this is not clear to me.
You have the BT account number which I am sure you will be able to trace the order from this.
thank you
Lumena Major
PaddyB
Moderator
Moderator
Message 6 of 11
Hi @lorri-gem,
Thank you for speaking to @JohnC2 earlier today. I'm happy you've received you voucher. You can place your order online at the BT Shop -www.shop.bt.com
You can also call the BT Shop on 0800 917 0510, they're open 9am to 5pm Mon - Fri.
PaddyB
lorri-gem
Message 7 of 11
Received voucher tried to shop BT online but it wont accept the voucher code. Please help as i am losing patience.
PaddyB
Moderator
Moderator
Message 8 of 11
Hi @lorri-gem,
I'm sorry you weren't able to place the order online. If you give the BT Shop a call tomorrow on the number I posted above, they'll be able to help you with the order.
PaddyB
JohnC2
Moderator
Moderator
Message 9 of 11
Hi @lorri-gem I wanted to check if you have called the BT Shop today and placed your order ok.
John
lorri-gem
Message 10 of 11
Yes thank you very much. It is sorted and order placed.
