Becca21
Message 1 of 4
Free fit bit
My internet went live on 13th November and iv had an email to tell me to expect an email within 14 days to claim my free fit bit. I haven’t had this so just called and been told it can take up to 30 days but the same posts on here don’t state 30 days!! Can you check what is happening please?
3 REPLIES 3
JohnC2
Moderator
Moderator
Message 2 of 4
Re: Free fit bit
Hi @Becca21 sorry you have not received your Fitbit code yet. Click on my profile and select the contact the mods option and we will be happy to chase this up for you.
Cheers
John
JohnC2
Moderator
Moderator
Message 3 of 4
Re: Free fit bit
Hi @Becca21 I called earlier sorry I missed you. I've checked and the 14 days from the order completion was the 27th. The email with the code will be sent today please can you check and let me know you have received it ok.
Cheers
John
Becca21
Message 4 of 4
Re: Free fit bit
I have received it thank you so much for your help.
