rbz5416
Message 1 of 11
Get Message to Openreach
I have a BB switch to BT scheduled next month. On the last three occasions I've switched ISP, it's gone wrong due to issues in the local cab. Who can I speak to in BT who has the ear of Openreach so I can ensure it doesn't happen again?
10 REPLIES 10
Message 2 of 11
Re: Get Message to Openreach
There is nothing you can do at the moment, you will have to wait to see if there is an issue with the order.
If you are moving from one FTTC provider to another, there will be issues if the cabinet is full, and there are no free ports, as any existing connection will be ceased.
rbz5416
Message 3 of 11
Thanks but nothing to do with capacity.
Struggling to accept that the preferred method is to break the connection & then spend a week trying to sort it out rather than do it properly in t he first place.
Message 4 of 11
changing ISPs means you lose your existing and should cab be full at that time then you will join waiting list and not get connected right away
Message 5 of 11
That would be normal, as its done as a cease and re-provide.
rbz5416
Message 6 of 11
It's "normal" to break the connection for week? I don't think so.
Message 7 of 11
I don't think anyone said it is normal to lose broadband for a week when changing ISP but you lose your connection and if it so happened your cabinet was full then you would lose your broadband altogether and join the waiting list
as @Keith_Beddoe  when changing ISP it is cease and reprovide
rbz5416
Message 8 of 11
That may not have been what @Keith_Beddoe meant but it IS exactly what he said.
I really don't know what it is that compels someone to have to post an "answer" to a question when they don't know the answer. I suppose it's a desire to keep the post count up. Had he simply skipped to the next post we wouldn't now be rambling on about full cabinets, which is completely irrelevant.
Now I'm prepared to accept that no one on the forum knows the answer to my question & if that's the case, so be it. But can I please have no more off-topic posts?
Message 9 of 11
I think @Keith_Beddoe  answered your question in message 2  there is nothing you can do until you actually have a problem
Message 10 of 11
How can somebody fix something before it is broken. There is a process that is followed, c99% of the time following the process results in a satisfactory conclusion. On the odd c1% of the time problems occur, until that problem does occur nobody can predict what it will be and can't predict a solution.
