brutus66
Message 1 of 5
Halo 3 to Fibre 2
how to down grade from Halo 3 to Fibre 2
4 REPLIES 4
garybs29
Recognised Expert
Message 2 of 5
Re: Halo 3 to Fibre 2
You probably can't, how long ago did you take out the halo 3 anyway?
-Richie-
Guru
Message 3 of 5
Halo 3 was launched around Feb/March so a downgrade is highly unlikely until you're outside the minimum term, when did you subscribe to Halo 3 ?
brutus66
Message 4 of 5
sorry i got that wrong i have halo 2 until next august
-Richie-
Guru
Message 5 of 5
A downgrade with a year left to run isn't something the BT systems will make available, you could try in the last 6 months of your minimum term but I suspect that will just show the current package available to extend, you'll most like need to wait until you've completed the minimum term and then downgrade.
