Message 1 of 3
Having 2 broadbands
I'm having BT broadband installed soon and, as of now, have Virgin Media TV, telephone, and broadband. I need to keep the Virgin Media stuff and have BT broadband as well. When BT installs the new broadband connection, will it drop my present provider, which I need to keep?
2 REPLIES 2
Message 2 of 3
Re: Having 2 broadbands
No, with Virgin you would need to cancel with them yourself rather than the gaining ISP doing it for you, so unless/until you cancel, both will be active.
Message 3 of 3
Thanks for the reply was worried then for a second 🙂
