Message 1 of 13
Home move to much slower speed
Thanks in advance
I'm am about to move homes (currently with halo 3) and have been told that the speed will go from 50mbps to 10 😳
Virgin have fiber at the home but bt don't and only have old copper wires so the aget says.
Is there a way I can cancel the contract early due to such slow speeds obviously not being realistic for someone working from home and general online life nowadays?
12 REPLIES 12
Message 2 of 13
Re: Home move to much slower soeed
@Alistair3
You would not be able to cancel the contract early, without paying cancellation charges.
The fact that your new home is slower makes no difference, you would need to take the remaining contract with you.
Message 3 of 13
Well that sucks 😕
Guess I'll need to buy myself out of the contract I suppose
Message 4 of 13
You may find that the speed you get is better than expected. Wait until you move in and see what the speed is. If its not good enough, and there is no other option, then you could then decide whether to cancel.
Message 5 of 13
Thanks, the agent told me I'd be lucky to get 10mbps. I'll be honest my current speed of 50 is only just adequate for work so I'll definitely have to switch.
Contract isn't due to end till Mark 2024 so that's going to be a painful bill 😬
Message 6 of 13
Sometimes if there is FTTP, its not visible to the sales people, as they only see the copper network.
Use the address checker for your new address, on the link below, and post the results, but edit out your address details first.
Message 7 of 13
 thanks for your help in this
Message 8 of 13
From the dslchecker your address can get FTTC of 80mb but there is currently a waiting list for your cabinet so you need to keep checking dslchecker until you see available then phone up and place order
Anonymous
Not applicable
Message 9 of 13
And to head off the usual next question...
No, there is no actual list. It's literally a case of checking back for an available port & bagging it before anyone else does!
Message 10 of 13
@Alistair3
You are going to get a much faster connection at your new house than where you are at the moment, once a port becomes available on the cabinet, which could be anytime, you just need to keep checking.
If you accept the slower 12Mbs ADSL2+ connection to start with, then as soon as a port becomes free, then upgrade to FTTC, it will save you an awful lot of money, and avoid the cancellation charges.
You may be surprised with the performance of the ADSL2+ connection, as download speeds tend to be more consistent than on VDSL, as the ADSL2+ equipment is located in the exchange, and has a direct physical connection to the core network.
