Newbie
Message 1 of 6
How does Auto Compensation work, when will mine get applied?
My service activation has been delayed and I had an auto compensation/credit of £100 applied to my account.
So I got my 1st bill and I was fully charged for the service and there is no credit/compensation visible anywhere in my bills or on my account?
When will I get this? How does this work?
5 REPLIES 5
Expert
Message 2 of 6
Re: How does Auto Compensation work, when will mine get applied?
The details can be found Here which states :
How will you pay me the compensation?
  • We'll add it as a credit to the next bill we send you after the missed appointment, activation of service, or fixing of the total loss of service fault
  • You won't be able to see the amount on the My BT App or BT.com until your bill's been generated
So you should see it on your next BT bill as a credit.
Newbie
Message 3 of 6
Which didn't happen, I got my bill, it's not there.
Moderator
Moderator
Message 4 of 6
Hi @UserX,
Welcome to the Community and thanks for taking the time to post.
Sorry to hear that the connection of your service was delayed.
Can you check the date we sent you the email about the auto compensation being applied and also check the date at the top of your last bill?
More than likely the bill was produced before auto compensation was applied to your account. If this is the case then you will see the credit on your next bill.
Any questions please let me know.
Matt
Newbie
Message 5 of 6
My bill is dated on 7th Nov but my payment come out on the 14th Nov. The auto compensation text I got is from 9th Nov.
Moderator
Moderator
Message 6 of 6
@UserX
That explains it then, the credit will show on your next bill 🙂
Have a good evening.
Matt
