Message 1 of 4
How to refer a friend to join BT and get £50 reward both?
Hi everybody,
As subject, would like to know how to refer a friend to join BT and get  £50 reward both?
I cannot find any link. Can any one help me? Thanks.
Angela
3 REPLIES 3
Message 2 of 4
Re: How to refer a friend to join BT and get £50 reward both?
The "Refer a Friend" scheme ended as from 10/09/2023.
Message 3 of 4
Hi gg30340,
Thank you.
Would like to know when will have similar scheme in the future?
Message 4 of 4
There are aparently no plans to run anything in the near future.
