commiczar
Message 1 of 8
I can not view online billing using the correct password log in
Same problem , but I can Log in but when I select account or anything except sales / upgrades, then it fails , and i get the message we cannot connect you yet , there appears to be a problem with this site , (mobile app works perfectly ), have check anti virus (norton ) and firewall , no problems with all permissions . ...help please
7 REPLIES 7
Moderator
Moderator
Message 2 of 8
Re: I can not view online billing using the correct password log in
Hi @commiczar and thanks for posting.
I've moved your post so we can offer some help with this. Are you able to post a screen shot of the error message you're seeing?
Cheers
David
commiczar
Message 3 of 8
Version:1.0 StartHTML:000000232 EndHTML:000001078 StartFragment:000000693 EndFragment:000001008 StartSelection:000000693 EndSelection:000001004 SourceURL:ms-appx-web://microsoft.microsoftedge/assets/errorpages/acr_error.htmThis page is having a problem loading
We tried to load this page for you a few times, but there is still a problem with this site. We know you have better things to do than to watch this page reload over and over again so try coming back to this page later.
commiczar
Message 4 of 8
tried using Internet explorer , worked fine ,With Edge I can log into My BT , but cannot load anything connected with account pages , Sales pages surprisingly work fine .. lol
Moderator
Moderator
Message 5 of 8
Thanks for confirming that @commiczar.
So you can log in using IE but not when using Edge? Is that correct?
Cheers
David
commiczar
Message 6 of 8
Hi David ,yes it works fine in IE , but not in edge . with edge it seems to loose link to account homepage . ican log in . using email and password , but it will not then go to account homepage , It's puzzling ,
commiczar
Message 7 of 8
used BT chat . but their take control app will not work at their end , Advisor suggested IE , he had no immediate corrective choices ,
commiczar
Message 8 of 8
Any further progress . on why Edge is not finding home page for "my BT "
