Twick
Message 1 of 5
I need to establish if I have an outstanding bill to pay
...cannot get the info from MYBT or BT.COM or by  phoning. I cannot afford to be cut off as working from home. Tried Twitter, FB, Messenger this is my last attempt - what the heck is happening? what can I do ?
4 REPLIES 4
imjolly
Message 2 of 5
Re: I need to establish if I have an outstanding bill to pay
If you have an outstanding bill BT have said they will not cut any off in current virus situation until end june
Twick
Message 3 of 5
Can we be sure of that ? Where did you see that w riiten? Thanks very much!!!
imjolly
Message 4 of 5
There are mod post on the forum confirming.  Mods are BT employees. Use search facility
this is just one
https://community.bt.com/t5/Bills-Packages/Self-isolation/td-p/2022922
Twick
Message 5 of 5
Brilliant thanks very much!!!!😁
