On the 2nd May 2017 an engineer came to my home to check on a connection and speed problem in the end he said their was a none problem with the latest hub and changed it for the previous generation hub. this fixed the problem happy days. Now 3 and half months later I have been billed £129.99 for the visit, I promptly phoned BT to tell them of their mistake only to be told that the report from the engineer said the hub had been wired up wrong and no mention about replacing the hub. Anyway I logged a complaint and waited for their reply which came 48 hours later as promised to be told that they could only go on the engineers report so would be upholding the charge, when I mentioned how come I now have a different revsion of the hub, only to be told anybody could have changed it. I need to take this further but BT have done nothing to check the report against what I know happened I was there I spoke to the engineer face to face I have a different hub I know what he told me and none of it is in the report.
Solved! Go to Solution.
Hi @nickturner,
I'll be able to dispute that charge and take a look at the engineer's report. Please can you send me in your details using the "Contact The Mods" link found in my profile?
PaddyB
Community Moderator | PaddyB | |
Did you get the help you needed? Help others by clicking on ‘Mark as accepted solution’ | Show your appreciation! Click on the star next to a reply to say thanks | Help guide to using the community? Click below |
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You |
This is the serial number of the hub BT are saying wasnt changed, can this be traced to the engineers itinerary of spare hubs?
Serial No.:- +068543+NQ50908618
This is the number of the hub he left me with because mine had a fault, he at no time said it was wired incorrectly only their was a fault on my hub and replaced it with the one with the number on above.
Hi @nickturner We are working on your case at the moment and will be in touch with you in a few minutes.
Cheers
John
Community Moderator | JohnC | |
