Message 1 of 2
Installation time for upgrade
Hi, I'm due to get Full Fibre 500 with BT Halo 3 installed next week. OR have already done the external bit so the next appointment is for the inside of the house. I wondered if there is an average time it takes to install, as I'm concerned at how long I might be without broadband (and connection to my work!). Any ideas?
1 REPLY 1
Message 2 of 2
Re: Installation time for upgrade
if fibre at outside your home then will depend on where you want the ONT and how easy it is for openreach fitter to do it - assuming openreach is happy to fit where you would like.
