V_Meldrew
Recognised Expert
Message 81 of 162
Re: Introducing BT Plus!
I wouldn't delay too long, I was told 14 days
stereohaven
Message 82 of 162
I too am monitoring speeds.
We have 14 days to cancel if required, not sure if that is from date of order or go-live.
The confirmation emails I have are very confusing while “My BT” can’t give me any broadband info, it just has an error message.
hasey66
Message 83 of 162
I was told this morning it was from activation day
hasey66
Message 84 of 162
Any upgrade in your speed today ?
hasey66
Message 85 of 162
In English please ?
Message 86 of 162
First of all BT Plus can't change the laws of physics, if your speed was below the previous Infinity1 speed cap it won't change. Speed is related to the distance from the cabinet.
The speed of your line is optimised by a system called DLM (Dynamic Line Management) which employs a number of technologies to give you the maximum speed your line can support. When you upgraded to BT Plus, this sytem reset everything back to default including removing a retransmission technology (G.Inp). Once DLM has had a chance to analyse your line, it will re-instate G.Inp with a commensurate increase in speed.
stereohaven
Message 87 of 162
Nope.
Still sat at just under 39mb.
Which is still 3mb faster than I ever got with Plusnet but now I have had closer to 50mb I would like it back! Smiley Very Happy
hasey66
Message 88 of 162
Thank you that’s very clear and a much better answer than I got over the phone this morning ! Let’s hope it works as you say!
benjsdavis
Message 89 of 162
this is not correct, you won't get double the discount - it will simply be referring to the discount you're recieving on BT Plus. Your package is £39.99, discounted from £58.99 - THAT is the discount that carries on, not your current discount. You will not and should not recieve 'double discount'.
Andy005
Message 90 of 162
@V_Meldrew @Dean007
It does in fact state further down in the even smaller small print that the freeze applies to line rental and broadband only. It does create some ambiguity though as the most prominent line is "We may change any prices....".
It could, and should be made clearer, it's not surprising that customers get told different things when contacting Customer Support. Proper beta testing and vetting would improve their communication markedly.
