ktall32
Message 1 of 4
Is BT full fibre 1 FTTP?
Hi, when looking at fibre broadband options, BT offers the full fibre 100 service which is FTTP.
However, the fibre 1 option is called "full fibre 1" but doesn't state it is FTTP as the name suggests.
Is full fibre 1 FTTP or just a name?
3 REPLIES 3
-Richie-
Guru
Message 2 of 4
Re: Is BT full fibre 1 FTTP?
F1 or Fibre 1 can be delivered FTTC or FTTP, Full Fibre means it's FTTP, so you'd get fibre to the premises.
Keith_Beddoe
Message 3 of 4
@ktall32
Are you going to place an order with BT Retail, or are you an existing customer?
Try this page, if you do not already have a BT phone number, then use the address checker.
Please edit out any personal details before you post the results.
licquorice
Message 4 of 4
@ktall32
I have moved your post to the Bill and Package board as its more appropriate.
Fibre1 just relates to the speed of the product (i.e 55/10) whereas full fibre indicates that the service will be provided by FTTP.
If you are already a BT customer, enter your phone number in the checker to see if FTTP is available, otherwise enter your address. https://www.broadbandchecker.btwholesale.com/#/ADSL
