Message 1 of 14
Is Unlimited Fibre Plan (74Mb) FTTC or FTTP?
I can't get FTTP installed, will this plan require drilling etc or just plug in the new router?
13 REPLIES 13
Message 2 of 14
Re: Is Unlimited Fibre Plan (74Mb) FTTC or FTTP?
What ISP is this with ?
Message 3 of 14
bt (social/home essentials)
I assume it's the same as full fibre 2?
Message 4 of 14
No, its FTTC.
Message 5 of 14
It's asking for a installation appointment on checkout...
Message 6 of 14
Message 7 of 14
As you are being offered an appointment slot , it’s assumed that you need an ‘full’ installation , it’s possible that if the property has had ‘BT’ type service in the past , then that can be reused, but if not , then depending on what type of area the property is in ( overhead with telegraph poles , or underground cable ) there may need to a hole made to get a cable from the outside to the inside , and a master socket fitting etc,
If  address hasn’t had a working BT type line for quite some time , even if there is evidence of the previous ‘line’ , like a master socket, dropwire from a pole ( if overhead ) it cannot be assumed the line will simply come back into  service , but it may , in which case the installer has a relatively easy job
Message 8 of 14
My phone socket has the text openreach bt on it, does this mean I won't need a visit? (this is how i get my current non-fibre internet from sky, so i assume this works?)
Message 9 of 14
It seems every broadband provider is requiring an installation appointment to get any speed above 11mb/s.
EE seems to think that i don't even have a phone line when i do.
Message 10 of 14
If you are SKY FTTC broadband customer and moving to BT FTTC then there should be no openreach visit
