Message 1 of 9
Locked to Fibre 1 speeds on Fibre 2 package.
Hi, I just got my fibre 2 package installed and the engineer informed me that i'm currently locked onto the Fibre 1 speeds. Here are my router stats,
otQWbC4
If anyone could help that would be amazing!
Thanks!
8 REPLIES 8
Message 2 of 9
Re: Locked to Fibre 1 speeds on Fibre 2 package.
You need to speak to customer services, 150 or 0800 800150
Message 3 of 9
Okay i'll try giving them a ring now, Thanks.
Message 4 of 9
Please let us know how you get  on @Okaydan . We're here to help if you need us.
Cheers
David
Message 5 of 9
 @DavidM Currently on the phone and it seems they don't understand about me being on the wrong package speeds and keep mentioning that it shows fibre 2 package on my account. If it's possible appreciate your help so much!
Thanks David.
Message 6 of 9
Hi @DavidM is it possible to get in contact with you please?
Message 7 of 9
Thanks for getting back @Okaydan .
I'll take a look at this for you. I'll drop you over a private message now so you can get in touch.
Cheers
David
Message 8 of 9
@DavidM Thanks for the reply, I've gone ahead and messaged you.
Thank you!
Message 9 of 9
Thank you @DavidM and the moderator team who helped me get put on the 80/20 profile, Really appreciate you guys!
