Message 1 of 2
Login on Android
I login OK to MyBT on my PC, but on my Android Tablet my correct login details are not accepted Why? What to do?
1 REPLY 1
Message 2 of 2
Re: Login on Android
If you are using the MyBT app try reinstalling it.
