anna-orban
Newbie
Message 1 of 3
M&S £40 voucher
I am a new customer and my new broadband order is eligible for a £40 M&S voucher. The broadband was activated on 24th August and I tried claiming the voucher today at https://www.broadbandbenefits.co.uk/marksandspencers/. However, the form does not recognise my order number and I cannot claim my reward. I have tried submitting both *Edited by Mod* but neither work.
Does anybody know how to fix this issue or whether there is a different way to claim the reward?
Thanks!
2 REPLIES 2
Message 2 of 3
Re: M&S £40 voucher
You should remove your reference number from your post. This is a public forum and the number is individual to you.
Have a read through this link about claiming
https://community.bt.com/t5/Bills-Packages/Claiming-a-BT-Reward-card/td-p/1857030
Moderator
Moderator
Message 3 of 3
Re: M&S £40 voucher
Hi @anna-orban Sorry you are having difficulty claiming your M&S voucher.
You should have an order ref starting AJM and you will need this to submit your claim. Post back and let me know if you can find that ref and claim ok or not.
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
