sguy455
Message 1 of 14
Marks and Spencer voucher-how do I chase up?
Hi guys,
I was offered the £40 M and S voucher for signing up along with £100 BT reward card. The reward arrived with no issues, but now the 45 days has elapsed and the M and S voucher has not arrived. I have completed the online form via the link to request the vouchers already.
Where do I complain about this?
13 REPLIES 13
Moderator
Moderator
Message 2 of 14
Re: Marks and Spencer voucher-how do I chase up?
@sguy455 Please use the 'click here to contact the mods' link in my forum profile to send in your details and we'll raise this with the promotions team. You can find the link by clicking on my username.
Neil
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
sguy455
Message 3 of 14
Thanks Neil, I have done this. If you can advise if there is anything else I should do that would be great
-Richie-
Expert
Message 4 of 14
Are the M&S vouchers not meant to be claimed from the 3rd party that referred you ? MoneySavingExpert ran that promotion I believe, the £100 which you've already claimed is claimed from BT
Moderator
Moderator
Message 5 of 14
Hi @sguy455,
When you claim the M&S voucher, did you do so using the link the link below?
https://www.broadbandbenefits.co.uk/marksandspencers/Default.asp
PaddyB
Community ModeratorPaddyB
Kudos”Kudos”
sguy455
Message 6 of 14
Yes I claimed using the 3rd party website, 45 days have elapsed and the vouchers have not arrived. The website says to chase it up after this time but does not indicate how to?
Moderator
Moderator
Message 7 of 14
Hi @sguy455,
That's okay thank you for confirming. We'll chase this with the promotions team and we'll get back to you once we know more.
PaddyB
Kudos”Kudos”
sguy455
Message 8 of 14
Thank you very much
Moderator
Moderator
Message 9 of 14
Hi @sguy455,
Thank you for sending in your details. I've picked up your case and have passed on your details to the Promotions team to investigate. I should have an update for you in next couple of days and I'll post back as soon as I know more.
PaddyB
Kudos”Kudos”
sguy455
Message 10 of 14
Thanks Paddy, I really appreciate your help.
