Mjconnolly
Message 1 of 3
Moving house - new address will not get FTTC for 3 months - advice please
Hi everyone, I currently have 76mbps broadband, and I get BT TV, HD pack and sport. I’m moving house in 2 weeks. Firstly the new house doesn’t have a phone line (although I believe it did in the past), and secondly the new cabinet enabling FTTC has only just been installed so it will take 3 months or so before I could get fibre again. Current speeds on that post code are in the 2 to 3 mbps range.
Luckily Vodafone 4g coverage is really good and I will get a wifi hotspot device. But what is the best approach to transfer my BT account to the new house? Should I just order the new line with no broadband, or ask if I can transfer everything over straight away pending the new cabinet going live?
thanks
2 REPLIES 2
Message 2 of 3
Re: Moving house - new address will not get FTTC for 3 months - advice please
Just use the normal BT Home Move process and any service that cannot be provided, would not be charged for.
I suggest you do that now, as two weeks notice is not long, and you will probably have to wait longer than that to get connected.
https://www.productsandservices.bt.com/manage/moving-home/
Mjconnolly
Message 3 of 3
Ok will do, thanks
