Do you mean
Recognised Expert
Accepted Solution
My BT, Broadband Usage Checker
Has anyone else tried to use the Broadband Usage Checker in the My BT section today, when I click onto the My Services Tab and then the Broadband option the little grey box where the link usually is, is just blank.
Re: My BT, Broadband Usage Checker
Hi plainview
It does seem to have a problem at the moment it was ok earlier today
john46 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Recognised Expert
Oh right, if its not working for you it must be a BT thing then and not me.
Cheers.
working fine for me
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side.
KP
Newbie
The same thing is happening on my account.
I have tried using Opera, Firefox, Chrome and IE9 browsers and disabled all security on them, but to no avail.
The blank grey box appears under both the Phone and Broadband tabs.
It has not worked for me all day today - from 11 am when I first tried it, and up to now it is still not working.
just tried again and it's still working
Distinguished Guru
Hi. Welcome to the forums.
This has been reported a number of times now, however mine has been working all the time when I've checked.
You may like to try one of my shortcuts, options 14d-14f to see if one of those works for you.
Newbie
The problem has not been resolved.  I am getting the same problem with my account that has been explained by other people.  I am just getting the grey space and no link to the broadband usage checker as of 4:38.p.m.
KP
Newbie
Thanks Andy.
Your link 14d worked fine.
https://www.bt.com/appsyouraccount/secure/cyahub.do
Newbie
I too am experiencing the same problem - got two bb accounts in two properties - still cannot view the monitor whatever way I try. Working perfectly last week.
