mychips
Message 1 of 4
Netflix still on my account when its supposed to be removed
I have been trying to get Netflix reomoved from my BT bill so I can pay directly myself but BT still are active on my Neflix account. Can this ever be resloved? NetflixBT50.jpg
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: Netflix still on my account when its supposed to be removed
Hi @mychips,
You should be able to cancel Netflix using Manage your TV Bolt-ons, you'll need to log in using your BT ID.
Give that a try and let me know how you get on.
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”Kudos”
mychips
Message 3 of 4
There is no option to cancel Netflix on the boltons
Moderator
Moderator
Message 4 of 4
Hi @mychips,
I'll be able to take a look at this for you. Please can you send me in your details using the "Contact The Mods" link found in my profile?
PaddyB
Kudos”Kudos”
