Megbrad85
Message 1 of 9
No Fitbit email
It's been nearly 3 weeks since I had everything installed and went live. Still no sign of an email for the fit bit? No response to emails I've sent either.
8 REPLIES 8
Moderator
Moderator
Message 2 of 9
Re: No Fitbit email
Hi @Megbrad85
I can have this chased up for you. Please send us in your details by filling out the contact the mods form in my profile.
Stuart
Community ModeratorStuartH
Show your appreciation!
Kudos”Kudos”
Megbrad85
Message 3 of 9
Re: No Fitbit email
There is no option to contact mods on your profile?
Moderator
Moderator
Message 4 of 9
Re: No Fitbit email
Hi @Megbrad85
It should appear next my profile picture when you click in there.
Stuart
Kudos”Kudos”
Megbrad85
Message 5 of 9
Re: No Fitbit email
Found it! Completed the form. Thankyou.
Moderator
Moderator
Message 6 of 9
Re: No Fitbit email
Hi @Megbrad85,
I picked up your case and I tried calling you earlier.
I will try and give you another call tomorrow.
Cheers,
Robbie
Community ModeratorRobbieMac
Kudos”Kudos”
Megbrad85
Message 7 of 9
Re: No Fitbit email
It was in my junk folder. All sorted. Thankyou
Moderator
Moderator
Message 8 of 9
Re: No Fitbit email
@Megbrad85 great, I'll let @RobbieMac know it's sorted  Smiley Happy
Community ModeratorNeilO
Kudos”Kudos”
Moderator
Moderator
Message 9 of 9
Re: No Fitbit email
Hi @Megbrad85,
Thanks for posting back.
I'm really pleased to see that you've got the code now.  I'll go ahead and close things off from here.
Cheers,
Robbie
Kudos”Kudos”
