Message 1 of 7
No broadband after house move
Moved home and transferred service and BT Home Hub3, on activation landline fine but no broadband, tried BT troubleshooter which says line is fine. Do I need an updated Home  Hub to get Broadband ? Any suggestions welcomed ...Thanks from a hopeless IT user.
6 REPLIES 6
Message 2 of 7
Re: No broadband after house move
@BMUD
What broadband package do you have at your new property,  as the home hub 3 is only suitable for ADSL (normal broadband). You need a smart hub 2 for fibre broadband.
Message 3 of 7
Only got the basic package. Spoke to BT, they are sending engineer.
Message 4 of 7
Hi @BMUD
Welcome and thanks for your posts!
Sorry for the delay connecting your services at your new address.  I understand that you've been chatting with my colleague on the phone and they're sending an engineer out.
Keep us posted with how the engineer gets on 😊
Thanks,
Robbie
Message 5 of 7
Engineer arrived today (15/11/21) at booked time and helpfully tested the line, confirming it is copper (not fibre), but said there was some interference on the line and broadband wasn't "syncing". He's informed Openreach to escalate the problem, Openreach will apparently call me back to arrange another appointment. Broadband has now been offline for 7 days and counting since supposed activation (08/11/21), but at least the landline works and I can take comfort it wasn't my  poor IT knowledge causing the problem. I'm, however, a little unsure why the broadband wasn't tested when it was initially supposedly activated ?
Message 6 of 7
A highly competent OPENREACH engineer arrived today (17/11/21) as arranged. They confirmed it was a line problem and located a rusty points connection problem on a pole 35m away which they repaired. They also sorted a fibre joint connection issue in the cabinet and now the blue light on my router lights-up and my Broadband works, hurray !!!
Message 7 of 7
@BMUD
You can give feedback on this form.
https://www.openreach.com/thank-an-engineer-form
It is appreciated.
