DanielS
Moderator
Moderator
Message 11 of 18
Re: Not received free Echo
Hi @grungernut,
@PaddyB is still investigating this for you. He should hopefully have an update tomorrow for you.
DanielS
PaddyB
Moderator
Moderator
Message 12 of 18
Hi @grungernut,
Thank you for taking my call today. The Rewards Team have got back to me this morning to say they Voucher to claim the Echo has been sent to your email. If you follow the instruction in the email to complete the claim, you should receive the ECHO in the next 4 weeks.
If you have any issues using that voucher, please post back.
PaddyB
grungernut
Message 13 of 18
Thanks for the support Patrick. I haven't received the email yet I will let you know if I have any problems once I have it.
Mark
grungernut
Message 14 of 18
Patrick, I still have not recieved any email, checked spam etc but nothing. Can you check it went to the correct address please.
JohnC2
Moderator
Moderator
Message 15 of 18
Hi @grungernut @PaddyB has left the office for today. He will be back on Friday and check this and update you then.
Cheers
John
grungernut
Message 16 of 18
Thanks john
This is getting very frustrating now. Patrick has been very helpful and said the reward team had sent me an email with the echo voucher code but I have not had and its just dragging on. If nobody else can deal with this then hopefully he can shed some light on it on Friday.
grungernut
Message 17 of 18
All sorted got the code today. thanks for the help guys.
JohnC2
Moderator
Moderator
Message 18 of 18
Hi @grungernut Thanks for the update and I'll let @PaddyB know it's arrived.
Cheers
John
