Community Manager
Community Manager
Message 11 of 18
Re: ORDI Check
@rbpios ah that's unexpected. Sorry about that. I'll give you a ring about it this morning, depending on what the issue is I might have to go back to Openreach.
Thanks for flagging @RobbieMac.
Community ModeratorStephanie
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
rbpios
Message 12 of 18
Re: ORDI Check
Can you enable it so I can DM you the message from the new provider?
Community Manager
Community Manager
Message 13 of 18
Re: ORDI Check
@rbpios my PMs have been turned on, I'm not too sure why you're having trouble getting in touch. Sorry about that.
I have just sent you a PM there, hopefully you can reply back to it.
Kudos”
rbpios
Message 14 of 18
Re: ORDI Check
Doesn't work. Forum give the following error:
"You have reached the limit for number of private messages that you can send for now. Please try again later."
I've never sent any private messages on the forum!
rbpios
Message 15 of 18
Re: ORDI Check
Here is the message I've received - I've removed references to my number by substituting with *s.
I have checked the Address you provided and this shows a number ending in ** as a BT single line (this basically just means a phone line on BT's network registered on their systems).
However, another check of ours is showing that the number *********** is not showing as a BT Single Line. This means either we have the wrong number or there is an issue on the phone line.
As a result we need to you to raise an ORDI with BT once again, as we are still unable to place any orders until we can confirm we have the correct line.
**INTERNAL**
Phone number ending in ** on QLA but not showing on tags.
Community Manager
Community Manager
Message 16 of 18
Re: ORDI Check
Hi @rbpios thanks for taking my calls today. I believe your new supplier has figured out the problem on their end, so fingers crossed this is resolved for you.
Kudos”
rbpios
Message 17 of 18
Re: ORDI Check
Hi Stephanie,
Just to say thank you for your help sorting this out. Hopefully all the databases say the same thing now!
All the best
R
Community Manager
Community Manager
Message 18 of 18
Re: ORDI Check
No problem, we got there in the end (hopefully!) 🙂
Kudos”
