rwlawrie
Message 1 of 3
Open Reach database - Wrong address
Hi,
I'm trying to order BT Infinity but am getting an error Ref# CON-0067 - I understand that this can be caused by Open Reach having the incorrect address - is there a way I can check this please?
Thanks,
Rob
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: Open Reach database - Wrong address
Hi @rwlawrie,
Welcome to the community forum. I'm sorry you're having problems placing your order online. Did you manage to get this sorted?
If not, I'll be able to take a look at this for you. You can send me in your details using the "Contact The Mods" link found in my profile?
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”Kudos”
rwlawrie
Message 3 of 3
Hi Paddy,
Yes all sorted now thank you.
Kind Regards
Rob
