DanJohn
Message 1 of 4
Openreach says i have Fibre available but i can't get Fibre
if you go over to the https://www.homeandbusiness.openreach.co.uk/fibre-broadband/when-can-i-get-fibre openreach website and select the PDF view and CTRL F the cabinet name BIRTLEY it says that my area has FTTC & FTTP available now but when i go onto the BT website and search my Postcode i don't have FTTC/P Available. Am I Missing something or is there any information where i can get which tells me when i will have FTTc/p available.
3 REPLIES 3
Message 2 of 4
Re: Openreach says i have Fibre available but i can't get Fibre
Try using your BT Retail phone number in the availability checker.
Broadband availability checker
Please remember to edit out your phone number before you post the results.
But leave the cabinet and exchange information showing.
Moderator
Moderator
Message 3 of 4
Hi @DanJohn,
Do you have an active BT Telephone service? If so can you enter the number on the link posted by @Keith_Beddoe?
This will help to show what service are available on your line.
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”Kudos”
DanJohn
Message 4 of 4
sorry for the late reply. I have also checked other postcodes around my neighbourhood and they seem to have fibre.
