Hi
I have overpaid on my last bill, just seeing whether I could get it sorted please.
Solved! Go to Solution.
If it isn't too much, then it is simpler just to leave it so that the overpayment amount is offset against next month's bill.
I can’t, I need that other payment back has I have other bills to pay.
You will need to call BT on 0800.800.150 and ask for the Billing Dept to see if they can help you.
