TimWells
Message 141 of 271
Re: P2P being throttled
Most Torrent client ENCRYPTION are bad or dont work fully
i use Vuze with Encyption RC4 with not normal ports aswell so hard to guess what im doing and i still get Throttled
ports numbers i use is well above 58 thousand range and have Randomize ports each time i start up Vuze aswell and not using bt Router either
So i would love to know how BT detect it and throttle it
Tim Wells
MTA MCSE MCTS MCITP MCM MCA Some of them need to be renewed but Looking for work
yessuz
Message 142 of 271
So, in that case, try uTorrent. Forced encryption only. It works perfectly 🙂
wrutless
Message 143 of 271
It doesn't work for me even forced, it used to but not any more
Stuartd
Message 144 of 271
I can't get the Glasnost test to show me the results, I have the latest version of Java installed but it just sticks at processing data after the tests have run and then nothing else happens no matter how long I leave it. Anyone else had this?
elle44
Message 145 of 271
I have now tried re-contracting 3 times via the phone and nothing has happened each time taking about an hour explaining to them why I need to re-contract.  them not having a clue what i am on about then no re-contract occurring absolutely nothing happens even after getting multiple assurances the re-contract will go through
Message 146 of 271
@ Stuartd
I have seen this I found a work round uninstall java and reinstall an older version it looks like the new version is not compatible with the glasnost test
Message 147 of 271
@elle44
You could try upgrading online by ordering the totally unlimited package, there have been some posts were this has worked
elle44
Message 148 of 271
where do i start that i have unlimited infinity 2 where do i order just start a new package? just ive got till may on my contract and its pricey if that gets canceled and a new contract is started
Sage
Sage
Message 149 of 271
Start as if you were a new customer, when you enter your details it will recognise you as an existing customer and do the upgrade for you.
That is what we have been told works although I haven't tried it.
It will be a new 12mth contract though whichever way you get it done.
elle44
Message 150 of 271
tried that good news you have already got bt sport and i cant do anything more
