DanJohn
Message 1 of 9
People have fibre around me but i don't
if you go over to the https://www.homeandbusiness.openreach.co.uk/fibre-broadband/when-can-i-get-fibre openreach website and select the PDF view and CTRL F the cabinet name BIRTLEY it says that my area has FTTC & FTTP available now but when i go onto the BT website and search my Postcode i don't have FTTC/P Available. Am I Missing something or is there any information where i can get which tells me when i will have FTTc/p available. I have also done a test on the bt speed checker. I have checked the post codes around me (around 5 minute walk) and they get fibre. I just want to know if i will be getting fibre because i really can't do much with the 600kb/s i have right now.
lLLAzim
8 REPLIES 8
Message 2 of 9
Re: People have fibre around me but i don't
unfortunately cab 6 is not fibre enabled and from dslchecker it is in planning stage  there is no timescale when upgrade will happen  others near you must be on a different cab to you
openreach won't move your line just so you can get broadband
DanJohn
Message 3 of 9
yes but according to the codelock website i am connected to two different cabinets P6 & P12. P12 has fibre so is there no way that i can use P12 for fibre?
Message 4 of 9
You are connected to cab 6 .  Code lookup shows the cabs in your area not the ones you are connected to so at present there is no fibre available on your cabinet
DanJohn
Message 5 of 9
Oh okay so i understand that i need to wait for Openreach to upgrade my cabinet to fibre but i don't understand why the PDF from openreach suggests that NEBR cabinet is fibre available.
https://www.openreach.co.uk/orpg/home/products/super-fastfibreaccess/downloads/sffa_exchange_lists/a...
CJT80
Expert
Message 6 of 9
NEBR is the Exchange that the cabinet is fed from....
The Cabinet is 6.
Kind Regards
CJT80
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
DanJohn
Message 7 of 9
oh okay thank you another thing (sorry for adding this on) an openreach engineer came over today and said that although cabinet 6 does not have fibre Cabinet 7 does and Cabinet 6 is linked to cabinet 7. He informed me that i could get in contact with BT and ask them to send an engineer out to allow cabinet 6 to receive fibre from 7 but when i contacted BT they just told me cabinet 6 has no fibre and they didn't even listen to me or take note when i was talking about cabinet 7.
Message 8 of 9
The engineer was talking rubbish and I hope you don't need him to sort out your connection.  You are connected to cab 6 and openreach will not change your cab just for a broadband connection
DanJohn
Message 9 of 9
okay thanks again for the help i guess i just have to wait which will be painful.
