Pyoungy52
Message 1 of 5
Previous package
Hi just wondering if I could revert back to the classic tv package which I had before now tv package
my son is very disappointed because he has lost all is programs from Nat geo wild which was supposed to be on nowtv but they but national geographic on instead
any advice would be helpful cheers
4 REPLIES 4
StewM
Guru
Message 2 of 5
Re: Previous package
Hi, @Pyoungy52 if you are within the 14 day cooling off period, then yes. Give BT a call.
Stew
Pyoungy52
Message 3 of 5
No I’m way past it about 6 months is there anything you can do
cheers
StewM
Guru
Message 4 of 5
You could try phoning BT and say you are disappointed at the loss of the channels. Did you know you would lose the channels, we’re you advised?
The legacy packages are no longer sold so they may just refuse to move you back.
Stew
Pyoungy52
Message 5 of 5
It was supposed to be on but they changed it to national geographic
as I was ordering it I think
obviously no info as it was start of lockdown when I ordered it
