adamrr8965
Newbie
Message 1 of 7
Price Rise 2016?
Hello all new to the forums.
Does BT generally have a price rise each year on their services
Thank you.
6 REPLIES 6
Message 2 of 7
Re: Price Rise 2016?
Distinguished Guru
Distinguished Guru
Message 3 of 7
Usually towards the end of the year so you should be safe for some months, but who knows?
adamrr8965
Newbie
Message 4 of 7
Ok thanks I was hoping it was sooner rather than later to use the 30 days notice get out clause. Not to worries though contract end on 27th september.
Moderator
Moderator
Message 5 of 7
Hey @adamrr8965,
Do you have any problems with your services or need any help?
I don't want you being unhappy until September, especially if it's something that I can help you with.
DanielS
adamrr8965
Newbie
Message 6 of 7
@DanielS
Hi we don't have any problems apart from the fact we are on standard broadband with BT and a local rival company KC has just gone live with their FTTH in our village. Got a cancellation fee from BT and its a huge at £288.
So will just run Bt alongside KC until the end of the contract, then close it.
Thanks for your help though.
Moderator
Moderator
Message 7 of 7
You are more than welcome @adamrr8965.
I'm sorry we don't have faster speeds available for you yet.
It's worth checking this link to see what speeds we have available.
DanielS
